Install the 1100MX/770MX Automatic Tool Changer
Please read this section before you begin installing your Automatic Tool Changer (ATC).
  • PathPilot You must update your controller to the latest version of PathPilot before installing and operating the ATC. If you don't, there's a risk that the ATC could become inoperable. Follow the instructions detailed in Before You Begin.
Required Tools
  • 1-1/2 in. adjustable wrench
  • 16 mm and 19 mm open-ended wrench
  • Marker
  • Metric hex wrench set
  • Phillips screwdriver
  • Small, flat-head screwdriver
  • Snips
  • Socket wrench, 13 mm socket, and (optionally) an extender
Air Requirements
  • Air Pressure Between 90 psi and 120 psi (620 kPa to 825 kPa).
    Use the FRL Filter-Regulator-Lubricator (PN 32457) or similar for this purpose.
Disassemble the Power Drawbar Button
  1. Disconnect the shop air supply from the machine.
  2. Remove four M5 × 0.8 - 10 mm button head cap screws that secure the Power Drawbar button cover.
  3. Disconnect the air lines from the Retract and Extend ports on the Power Drawbar.
    Power Drawbar air line routing.
  4. Disconnect the air line from the Air Supply port on the Power Drawbar button.
  5. Remove two M4 × 0.7 - 50 mm socket head cap screws that secure the Power Drawbar button to the spindle head. Then, cut the cable ties that secure the air lines together.
  6. Remove the Power Drawbar button from the spindle head.
Install the Air Cylinder
  1. Attach the air cylinder on to the ATC main assembly.
    Putting the air cylinder into the ATC main assembly.
  2. Secure the air cylinder to the ATC main assembly with a 12 mm hex wrench (provided) and two M14 × 20 mm socket head cap screws.
    Putting the air cylinder hardware into the air cylinder.
  3. Connect the air lines from the ATC main assembly to the air cylinder as follows:
    • Connect the short air line to the front of the cylinder.
    • Connect the long air line to the back of the cylinder.
Mount the Automatic Tool Changer Bracket
  1. Identify the four provided standoffs that are used to mount the ATC to the Z-column:
    • Three fixed standoffs
    • One tilt standoff
  2. Remove the flange nuts and the washers from the standoffs, and then set them aside.
  3. Identify and remove the four set screws on the Z-column with a flat-blade screwdriver.
  4. Install the four standoffs on the Z-column as shown in the following image.
    Four standoffs installed on the Z-column.
  5. Securely tighten the standoffs on the Z-column with a 1-1/2 in. adjustable wrench.
  6. Put the ATC mounting bracket on the standoff's threaded studs as shown in the following image.
    ATC mounting bracket moving on to the four standoffs.
    Verify that the tilt standoff's eccentric cam fits into the large slot on the ATC mounting bracket.
  7. Secure the bracket by reinstalling the washers and flange nuts that you removed in Step 2 with a 13 mm socket.
  8. Pull the bracket toward the front of the machine. You'll make adjustments to the location of the bracket later in this procedure, but we recommend starting with it moved forward.
Install the Main Assembly
  1. Remove the four preinstalled M8 × 1.25 - 16 mm socket head cap screws and washers from the bottom of the ATC electrical cabinet. Then, set all aside for later use.
    Team Lift Required: You must have the aid of more than one person to lift and move the object. The object is heavy, and lifting it by yourself can cause serious injury.
  2. Lift the ATC main assembly on to the mounting bracket.
    ATC main assembly positioned above the mounting bracket.
  3. Align the locating pin on the ATC main assembly with the matching hole in the mounting bracket.
  4. Secure the ATC main assembly to the mounting bracket with the four M8 × 1.25 - 16 mm socket head cap screws and washers that you set aside in Step 1.
Level the ATC
Prepare the Machine
  1. Push the tool tray toward the spindle.
    Tool tray moved in toward the spindle.
  2. Verify that the linear bearing on the ATC is flush with the ATC main assembly.
    Linear bearing flush with the ATC main assembly.
  3. Find a straight rod between 8 in. and 12 in. (203 mm and 305 mm) long. Verify that it's straight: roll it on a known flat surface (like a granite surface plate).
    You'll use the rod to verify that the ATC is correctly installed on the mill, so it must be straight.
  4. Put the alignment rod into a tool holder.
  5. Put the tool holder into the fork so that the groove in the tool holder slides into the fork, and so that the drive slot aligns with the dog. Don't rest the tool holder on top of the fork.
  6. Put a machinist's square on the machine table.
Examine Perpendicularity in the Y Direction
  1. Verify that the rod is perpendicular to the machine table in the Y direction: compare the rod's position to the vertical edge of the machinist's square.
  2. Loosen the flange nuts on the standoffs.
  3. Turn the tilt standoff with an adjustable wrench, and slowly pivot the ATC until the rod is perpendicular to the vertical edge of the machinist's square.
    Tilt standoff.
  4. Tighten the flange nuts with a 13 mm socket.
  5. Reexamine the alignment of the ATC in the Y direction. If the rod isn't perpendicular to the vertical edge of the machinist's square, repeat Steps 2 through 5.
Examine Perpendicularity in the X Direction
  1. Verify that the rod is perpendicular to the machine table in the X direction: compare the rod's position to the vertical edge of the machinist's square.
  2. Loosen the two socket head cap screws on the linear rails.
    Socket head cap screws on the linear rails.
  3. Slowly pivot the linear rails up or down until the rod is perpendicular to the vertical edge of the machinist's square.
  4. Tighten the socket head cap screws.
  5. Reexamine the alignment of the ATC in the X direction. If the rod isn't perpendicular to the vertical edge of the machinist's square, repeat Steps 2 through 5.
Examine the Alignment of the Carousel Door Opening
  1. Remove the tool holder from the fork, and set it aside.
    You'll need this tool later in the installation procedure to make further alignments.
    1. Insert the power plug(s) into the wall outlet. If your system is hardwired, restore power to the circuit breaker(s).
    2. Turn the PathPilot controller strip to ON.
    3. Turn the Main Disconnect switch to ON on the side of the electrical cabinet.
    4. Twist out the machine's red Emergency Stop button, which enables movement to the machine axes and the spindle.
    5. Press the StartReset button.
    6. Bring the machine out of reset and reference it.
  3. Verify that the ATC is all the way forward (toward the spindle), and then slowly move the Z-axis down (-Z) to examine the clearance of the carousel door opening.
  4. Verify that the carousel door opening is approximately equal to the front back and left of the spindle mounting flange:
    • If the carousel door opening is approximately equal, go to Step 8.
      Distance between the carousel door opening and the spindle mounting flange.
    • If the carousel door opening must be adjusted, go to Step 5.
  5. Loosen the four socket head cap screws that secure the ATC main assembly to the mounting bracket with a 6 mm hex wrench.
    Socket head cap screws securing the ATC main assembly to the mounting bracket.
  6. Adjust the carousel door opening as required:
    • If the Carousel Door Opening is Contacting the Front Pivot the ATC around the locating pin on the bottom of the mounting bracket toward the front of the machine (closer to you).
    • If the Carousel Door Opening is Contacting the Back Pivot the ATC around the locating pin on the bottom of the mounting bracket toward the back of the machine (closer to the machine column).
    • If the Carousel Door Opening is Contacting the Left Loosen the four flange nuts that attach the mounting bracket to the column to move the bracket forward or backward.
      Moving the ATC mounting bracket could change the position of the tilt standoff (on the Z-column). If you move it, you must verify that the ATC is still correctly installed; go to Install the 1100MX/770MX Automatic Tool Changer.
      Repeat this step as needed.
  7. Tighten the socket head cap screws and the flange nuts (if you loosened them in Step 5).
  8. Move the tool tray to its retracted position.
  9. Center the machine table: from the PathPilot interface, in the MDI Line DRO field, type G20 G53 G1 X9 Y-5.5 Z0 F20G20 G53 G1 X7 Y-3.75 Z0 F20G20 G53 G1 X5 Y-3.125 Z0 F20G20 G53 G1 X9 Y-4.75 Z0 F20. Then select the Enter key.
  10. Power off the machine and the PathPilot controller.
    4. Remove the power plug(s) from the wall outlet. If your system is hardwired, isolate the machine by opening its circuit breaker(s).
    5. Follow correct lockout/tagout procedures.
Make Air Connections
  1. Cut the cable tie that secures the ATC cables and plastic tubes together with snips.
  2. Route the loose ends of the two 1/4 in. plastic tubes connected to the ATC main assembly through the enclosure knockout, up the energy chain, and toward the Power Drawbar. Then, pull the air line from the FRL back through the energy chain.
    Crush Hazard: If the ATC isn't completely retracted, it could move once the air is reconnected. When you reconnect the air, you must keep your hands away from the ATC.
  3. Trim and connect the loose ends of the 1/4 in. plastic tubes in the following order:
    1. Connect the Retract (PDB Bottom) airline to the bottom push-to-connect elbow on the Power Drawbar.
    2. Connect the Advance (PDB Top) airline to the top push-to-connect elbow on the Power Drawbar
    3. Connect the air supply line from the FRL to the air in port in the ATC main assembly, as shown in the following image.
      Air in port in the ATC main assembly.
    4. If you haven't already done so, connect your shop's air supply to the FRL.
Make Electrical Connections
  1. Route the ATC power cable and the USB cable toward the rear of the machine and out of one of the enclosure knockouts.
  2. Put the USB cable in the access hole in the rear of the stand toward the controller.
  3. Put the USB cable into any open USB port on the PathPilot controller.
  4. Connect the ATC power cable to the ATC Power connector on the side of the electrical cabinet (below the Enclosure Lights Power connectors).
Verify the Installation
    You must update your controller to the latest version of PathPilot before operating the Automatic Tool Changer. If you don't, there's a risk that the ATC could become inoperable.
  2. If you have not yet done so, you must make sure that the PathPilot controller is updated to the latest version of PathPilot: From the Status tab, select Update. Then, follow the on-screen instructions.
  3. From the PathPilot interface, on the Settings tab, select the ATC radio button.
    ATC radio button on the Settings tab.
    The ATC tab appears in the PathPilot interface.
    If prompted, you may need to update the firmware for the ATC. Follow the on-screen instructions.
  4. Load a tool into the spindle:
    1. Push and hold the colletdrawbar open button on the side of the ATC.
      Collet Drawbar open button on the side of the ATC.
      The colletdrawbar opens.
    2. Load a tool into the spindle.
    3. Release the button.
      The colletdrawbar closes.
  5. From the PathPilot interface, on the Main tab, in the RPM DRO field, type 1000. Then select the Enter key.
  6. Select FWD.
    The spindle starts.
  7. From the Status tab, make sure that the VFD Running green light comes on.
    VFD Running light on the Status tab.
    If the VFD Running light did not come on in the previous step, we can help. Email support@tormach.com to contact Tormach Technical Support for guidance on how to proceed.
  8. Select Stop.
    The spindle stops.
