Power Drawbar Maintenance
Examine Air Pressure
Appropriate air supply helps with smooth actuation, and prevents premature component failure.
  • Examine the air to the Power Drawbar to make sure that it's:
    • Between 90 psi and 120 psi (620 kPa to 825 kPa)
    • Been lubricated with common air tool oil
Lubricate the Power Drawbar
  • Every 5000 cycles (or six months — whichever comes first), use Anti-Seize to lubricate the following parts on the Power Drawbar:
    • Contact surfaces between spring washers
    • Eccentric pivot mount
    • Top of the drawbar (below the drawbar flange and the spring washers)
Examine Wear Items
