Install the Air Cylinder
  1. Attach the air cylinder on to the ATC main assembly.
    Putting the air cylinder into the ATC main assembly.
  2. Secure the air cylinder to the ATC main assembly with a 12 mm hex wrench (provided) and two M14 × 20 mm socket head cap screws.
    Putting the air cylinder hardware into the air cylinder.
  3. Connect the air lines from the ATC main assembly to the air cylinder as follows:
    • Connect the short air line to the front of the cylinder.
    • Connect the long air line to the back of the cylinder.
