Install the Power Drawbar
Required Tools
Air Requirements
  • Air Pressure Between 90 psi and 120 psi (620 kPa to 825 kPa).
  • Air Volume At least 6 CFM at 90 PSI. Check with your plasma source manufacturer in case your model requires more volume.
    Use the FRL Filter-Regulator-Lubricator (PN 32457) or similar for this purpose.
Prepare the Machine
  1. If there's already a Tormach Tooling System (TTS) tool holder in the spindle, remove it.
  2. Verify that you can access the inside of the spindle cabinet: jog the Z-axis down (-Z) until it is about 6 in. (15 cm) from the machine table.
  3. Power off the machine and the PathPilot controller.
    4. Remove the power plug(s) from the wall outlet. If your system is hardwired, isolate the machine by opening its circuit breaker(s).
    5. Follow correct lockout/tagout procedures.
Disassemble the Original Power Drawbar
Assemble the Power Drawbar
Install the FRL (1100M/MX, 770M/MX Only)
We're continuously improving our products, so your machine may vary from the photos in our documents and videos. While the images may vary, the concepts still apply.
  1. Clean the FRL to make sure that it's free of dust.
  2. Remove and discard the plastic inserts from the FRL.
  3. Identify the dial provided, and then put two layers of thread seal tape on its threads.
  4. Attach the dial on the front of the FRL.
  5. Identify the two quick-connect bushings and the two NPT reducers provided. Connect the quick-connect bushings to the NPT reducers.
  6. Put two layers of thread seal tape on the threads of the NPT reducers.
  7. Attach the NPT reducers to the valve housings on either side of the FRL.
  8. Determine a location to install the FRL. We recommend installing it on the back of the machine's chip pans.
    FRL installed on the machine.
  9. Use the FRL bracket as a template to mark the two hole locations, and then drill two holes.
  10. Install the FRL bracket on the machine with your own hardware.
  11. Connect the air lines to the quick-connect bushings.
Set Up the FRL (1100M/MX, 770M/MX Only)
Make Air Connections
Adjust the Power Drawbar
After the initial installation, you must complete a final drawbar tension adjustment. For more information, see Adjust the Drawbar Tension. If you don't complete a drawbar tension adjustment, there's a risk of tool pull-out.
This adjustment sets the highest possible drawbar tension while still allowing the Power Drawbar cylinder to release the tool. For information, seeAbout Drawbar Tension.
After the initial installation, you must examine the drawbar tension weekly. During periods of heavy use, examine the drawbar tension more frequently. If you don't, there's a risk of tool pull-out.
To adjust the drawbar tension:
  1. Put an empty Tormach Tooling System (TTS) tool holder into the collet.
  2. While using one hand to support the tool holder, use the other to push the Release Tool button.
  3. Depending on whether the tool holder releases or not, do one of the following:
    • If the Tool Holder Releases Tighten the Power Drawbar in quarter-turn increments with two adjustable wrenches. After each turn, push the Release Tool button. Stop when the tool holder does not release. Then, loosen the Power Drawbar one quarter-turn with two adjustable wrenches.
    • If the Tool Holder Doesn't Release Loosen the Power Drawbar in quarter-turn increments with two adjustable wrenches while pushing the Release Tool button. Stop when the tool holder releases.
  4. Make a visual reference to help you set or adjust the drawbar tension in the future: use a paint pen to make a witness mark on both the head of the drawbar and the end of the spindle.
While machining, the Tormach Tooling System (TTS) collet holds a Tormach Tooling System (TTS) tool holder in the spindle by applying a clamping force to both the shank and the shoulder of the tool. The tension force that is applied to the drawbar pulls the Tormach Tooling System (TTS) collet into the spindle taper, which then applies the clamping force to the Tormach Tooling System (TTS) tool.
The force on the drawbar — known as drawbar tension — is applied differently depending on the tool changing method:
  • Automatic (using the Power Drawbar) Tension is applied by the compressed spring washers.
  • Manual Tension is applied when you tighten the drawbar into the collet using a wrench.
Adjust the Initial Setup
In this adjustment, you'll verify that there's enough clearance between the end of the drawbar and the Power Drawbar cylinder.
If you don't do this adjustment, there's a risk that the drawbar can loosen, or that operations can be louder than normal.
  1. Examine the space between the hex head screw on the Power Drawbar cylinder's rod and the top of the drawbar.
    Correctly spaced drawbar and Power Drawbar cylinder.
  2. Verify that the gap is between 3/64 in. and 1/8 in. (1 mm and 3 mm). Depending on the size of the gap, do one of the following:
    • Between 3/64 in. and 1/8 in. (1 mm and 3 mm) You have completed adjusting the initial setup. Go to Operation.
    • Less Than 3/64 in. (1 mm) Go to Step 3.
  3. Disconnect the shop's air supply from the Power Drawbar button.
  4. Pull out the quick-release pin.
  5. Pivot the Power Drawbar cylinder assembly to the left so that you can access the Power Drawbar cylinder's rod.
    Power Drawbar cylinder pivoted to the left.
  6. Remove the hex head screw on the Power Drawbar cylinder’s rod with an adjustable wrench, and set it aside.
    Hex head screw on the Power Drawbar cylinder's rod.
  7. Remove the M16 washer from the Power Drawbar cylinder’s rod, and set it aside.
    M16 washer removed from the Power Drawbar cylinder's rod.
  8. Put the hex head screw back in, and then tighten it completely with an adjustable wrench.
  9. Pivot the Power Drawbar cylinder to the original location.
  10. Push in the quick-release pin.
  11. Reconnect the shop's air supply to the Power Drawbar button.
  12. Examine the space between the hex head screw on the Power Drawbar cylinder’s rod and the top of the drawbar.
  13. Verify that the gap is between 3/64 in. and 1/8 in. (1 mm and 3 mm). Depending on the size of the gap, do one of the following:
    • Less Than 1/8 in. (1 mm) Go to Step 14.
  14. Find the three provided M14 flat washers.
  15. Put one M14 flat washer under each mounting post on the Power Drawbar cylinder.
