Power Drawbar Diagrams and Parts Lists
BT30 Power Drawbar Cylinder
ID Description Quantity
1 Power Drawbar Mount Plate (PN 37747) 1
2 Pneumatic Cylinder, Double Acting, 100 mm Bore, 25 mm Stroke, 2-Stack (PN 50450) 1
3 BT30 Power Drawbar Standoff, M14 × 2 - 145 (PN 39710) 3
4 Fitting, Elbow, 1/4 NPT to 1/4 in. PTC (Male) (PN 31324) 2
5 Fitting, Branch Tee, 1/4 NPT to 1/4 OD Tube (PN 31325) 1
6 Screw, Hex Head Cap, M16 × 1.5 - 25 (PN 31322) 1
7 Washer, Flat, M16 (PN 31445) 1
8 Screw, Flat-Head Cap, M14 × 2 - 40 (PN 38285) 3
9 Tube, 1/4 in. OD, Plastic (Red) - 125 mm (PN 38408) 1
TTS Power Drawbar Cylinder
2 Pneumatic Cylinder, Double Acting, 100 mm Bore, 12 mm Stroke, 3-Stack (PN 31313) 1
3 Power Drawbar Standoff, M14 × 2 (PN 38282) 3
5 Fitting, Branch Tee, 1/4 NPT to 1/4 OD Tube (PN 31325) 2
9 Tube, 1/4 in. OD, Plastic (Red) - 125 mm (PN 38408) 2
Power Drawbar Push Button
1 Power Drawbar Push Button Base (PN 38217) 1
2 Power Drawbar Push Button Cover (PN 38218) 1
3 Push Button Air Valve (4-Way, 5-Port) (PN 37295) 1
4 Fitting, Male Connector, 1/4 NPT to 1/4 in. PTC (PN 32212) 2
5 Fitting, Elbow, 1/4 NPT to 1/4 in. PTC (Male) (PN 31324) 1
6 Fitting, Muffler (Flat), 1/8 NPT (PN 37297) 2
7 Screw, Button Head Cap (Flanged), M5 × 0.8 - 10, Stainless Steel (PN 38205) 4
8 Screw, Socket Head Cap, M4 × 0.7 - 50 (PN 38220) 2
9 Power Drawbar Push Button Spacer (PN 38219) 2
10 Decal, Power Drawbar, Release Tool (PN 37340) 1
